wplash420
New member
 - california
Hello, first time posting here. I'll keep it short.
I've been looking for a three phase 5 wire tester. I would like to use it for startup testing. This would be advantageous in the fact that I could simply attach the 3 phases, one neutral, and one ground leads onto their respective lugs, busses, or bars. And then simply leave the leads running out through the deadfront. Then replace the panel cover, and energize it. This would allow me to test for proper voltage, and then de-energize and remove the leads. Which would conform to NFP70E.
In short, has anyone seen a tester that would work this way? Or should I simply stick with the old single phase at a time tester?
Thanks for your time.
