mkgrady
- Massachusetts
How do I control a cable box behind a closed cabinet door when the box is in a different room?
I have used those gizmos where you put a little eye outside the cabinet that receives an IR signal and run a cable from a controller to each component. But those cables are pretty short.
I need to put a sensor at the tv that will control a cable box 30 feet away. What hardware and control wire do I need?
