liquidtite
- Ny
I remember a few years ago I was in a factory and the voltage system was new to me .
The mechanic I was working with said the system was a corner grounded delta .
I forgot the exact voltages phase to ground and phase to phase ,but I remember that one of the phases was grounded so if you were to put tester on that phase and on ground you would read 0 .
When I was explaining the voltage to a Forman at work recently he said that the system I was explaining was a highleg delta but I think it is a diff system than highleg .
I tried looking up all the diff systems wye and delta online but only could find
a few .
If some one could put down the diff systems I would really appreciate it.
also is the corner grounded delta diff from the high leg like I thought or is it same
thanks for your time
a few .
