electrickangaroo
- st.petersburg fl
ok. so here it goes. I will explain the best way I can. I have a exterior panel (nema 3 R ) on the side of a home that has a 2in pvc pipe going up from the hub into the soffit with all the supply wires that feed the home inside it. the panel is fed from the meter to the right of it 3 ft away. I'm being told that the 2in pvc pipe needs to be removed and all the feeders need to come through the block wall into the back of the panel. In my opinion I would be unable to protect all those feeders dropping down inside the wall from someone who would like to pound a nail or screw through the interior drywall. I'm normally a commercial electrician so forgive me if I sound stupid here but is there a code that prevents the feeders from dropping out of the soffit and down the exterior wall in pipe and into the panel???? thanks
