mbrooke
Batteries Included
- United States
- Technician
Anyone know how to obtain old NEC versions such as those from the 60s and 70s?
I have hard copies that I might be willing to part with. 71 75 78
I might consider them. How much?
But does any one have the PDF versions or at least how to obtain them?
Scan the hardcopies (process them with OCR software and proofread them if you want them searchable) and convert them to PDF.
That is alot of work....
I believe Mark Shunk had the bindings cut on some old books so he could just put them in the scanners document feeder to make it easier.![]()
I still would not want that job. Even the smaller earlier versions would be a task. Marc is nuts....![]()
I doubt they had pdf versions then and I bet they never bothered to make it a pdf.
I have PDFs of the codes from 1888 to 1920.
Yes, there are companies that will do that for you. My son had that done with some of his engineering text books that he wanted to keep, but did not want the bulk of the physical books.I believe Mark Shunk had the bindings cut on some old books so he could just put them in the scanners document feeder to make it easier.![]()
Predecessors to, and early versions of, the NEC, 1881-1918, PDF format.
Click here.
Ignore all the fluff about signing up. Just click the "Download this file".
Neither would I and I don't know how you would deal with the two side to scan issue.
I can't argue with that last part but I do miss his participation.
Thanks!
But no latter versions?
Very cool, Ken. Thanks. This fills in the hole in my collection. I hadn't been able to afford the actual hard copies that I've seen sold.
Click here.
