prorod67
- NW Tennessee
What is a bedroom as far as NEC is concerned?
If it's a bedroom you would have a smoke detector in it right, as opposed to an office where you wouldn't.Thank You, Dennis!! I know toooo many here will know better than me, but HO purchased panel with breakers and the AFCI's are costing us about 60 plus tax, and I want to make sure I do not do anything thinking it is code, and HO find out it was not. Working off 2008 NEC and this is my first major residential job. Whatever I have to do is fine and, by no means, am not trying to dispute code, just want to be fair and Accurate to HO!!
I have a closet in my living room. Does that make it a bedroom?
Since I am in the same state as the OP I might be able to help him decide!
I know inspectors differ from one location in the state to the other but everyone that I deal with is the same as far as determining if a room is a bedroom or not. The very first thing they look at when someone claims the room isn't a bedroom is if it has a closet or not!
I know this has been mentioned but I just wanted to point out that's exactly what the inspectors here use to determine the room. Well one of the main things anyway. There may be cases where it's very obvious that the room isn't being used for a bedroom and an inspector might be convinced. But most here use the "what if" rule a lot. "What if" they sell it and the new owner changes it to a bedroom, or the current owners change their mind and convert it to a bedroom?:roll:
For those that don't know, Tn currently only requires AFCIs for bedrooms.
One of the few good decisions by the state IMHO!:thumbsup:
Also why wouldn't you have to put an AFCI in it? "...or similar rooms or areas." A room with a closet whether used as a bedroom or not, is still a similar room.
Awww.Apparently TN only requires AFCIs for bedrooms
We had a designed storage room with built in shelves and a closet for clothes storage. Remaining width less than three feet and the plan checker called it a bedroom and required an egress window.I have a closet in my living room. Does that make it a bedroom?
