I would like to find an outlet strip with 8 receptacles that will be installed in an environement that can range from -20 C to +60 C.  The Humidity range (above 0 C of course) is 20% to 90% relative humidity.
I would like to use a GFCI outlet strip. Will this likely only come with a plug that has the GFCI protection? Or will each outlet in the strip have GFCI protection?
Will the outlet that I plug the outlet strip need to be GFCI? If the main outlet is GFCI, does the outlet strip have to be GFCI? Is there any harm in making the outlets, the plug, and the main outlet all GFCI?
