mbrooke
Batteries Included
- United States
- Technician
Why cant I find them :blink:
Not sure, but aren't they mounted atop the short square tower frames (one in foreground, other off to right)...???Why cant I find them :blink:
141222-1327 EST
My guess is the same as Smart $. That small object bridged across a line pair would have no other purpose. There doesn't appear to be any other connection than the two high voltage posts.
Those are air terminals which are part of lightning protection, and surge arrestors which inadvertently are part of a lightning protection system. Both found in NFPA 780, but 780 doesn't apply to utility structures.
IDK... the OP asks about lightning arrestors, but the picture caption says "Surge (lightning) arrestors...". My impression is they are not the same. Air terminals typically extend to the highest point of the yard. Some yards use several parallel wires from side to side.Potential transformers? Two primary bushings, secondary conduit.
Here is a labeled picture I found on the web, it might help.
Good picture. Around here, the 34.5 kV side would be the distribution lines! Here, only old substations still do such low voltage distribution in inner cities.
