DSpencerMEP
- Brownsburg, IN
If a buss plug is tapped off of a buss duct, do you have to use the tap rule in your calculation?
240.2
Tap Conductors. As used in this article, a tap conductor is
defined as a conductor, other than a service conductor, that
has overcurrent protection ahead of its point of supply that
exceeds the value permitted for similar conductors that are
protected as described elsewhere in 240.4
