mstrlucky74
- NJ
Oh sh$&.... How can I confirm that? Thanks
Unless the photo is reversed, the plug is a US standard 120V-20A plug and needs a 20A receptacle with crossed slots. You just do not see them much on US products.Might be buying treadmill that was suppose to be shipped to Europe. Is this a European plug. Can this be used in the states?
Yup, thanksI agree.
It would be a NEMA 5-20
Turn your head and plug it in.....Invite someone over to try your new treadmill, wait in the other room...Oh sh$&.... How can I confirm that? Thanks
The NEMA text on the plug suggests that it is not European.Might be buying treadmill that was suppose to be shipped to Europe. Is this a European plug. Can this be used in the states?
As Goldilocks pointed out a few posts back, if it has a variable speed drive, the supply frequency should be OK. If all else fails, read the instructions!The 50/60 Hz is not likely to bother the motor much just the speeed calibration. A 50Hz motor plugged into 60Hz will run 20% faster at a given setting.
As the motor is variable speed this is less relevant but 10 mph is now 12 mph.
The 220V wouldn't be an issue. But I don't know anywhere in Europe use that plug.It does look designed to connect to a US system but as it can take 220v could connection Europe also.
I was thinking of this more from the user interface. You set the machine to run 12 min miles like you do in the gym and wonder why it is such hard work. It is because you are actually running 10 min miles.As Goldilocks pointed out a few posts back, if it has a variable speed drive, the supply frequency should be OK. If all else fails, read the instructions!
Here's a list:
http://www.worldstandards.eu/electricity/plugs-and-sockets/
If the rpm/mph counter uses line frequency as its time source for counting pulses (not unlikely), then it will count for a 12% shorter time interval, so a reading of 6mph would really be 7.2mph.Thanks everyone . I bought the treadmill ran the separate 20a circuit and its works fine. I must say that it's seems i can't get to my usual mph as its too hard. Usually I run at 6.7mph but it's seems like 6.1mph on this treadmill is the same effort.
This assumes, though, that the manufacturer forgot to program the correction.
You can use a measuring wheel of the type used for laying out or measuring long horizontal distances to check the calibration. Or you can measure the circumference of the belt and count belt passes per minute.
Good point. If the OP wants comparative numbers, he can measure his heart rate while at max effort.Or you could just put it on a speed that you can do and worry about something else......![]()
