Would like opinions on the following.
I am doing the electrical on a new residential build.Owner tells me that she will be using a portion of the garage for woodworking. There are a variety of tools, all 120 volt. Drill press, table saw, mitre saw,air compressor, etc. The length of the runs are between 80 and 100 ft from the panel(opposite end of house). She tells me that only 1 or 2 pieces of equipment will be running at a time.There are a total of 8 receptacles in this area.Does running 4 20amp circuits (12/2NM - 2 receps /circuit) sound reasonable? Once drywall is up future access is almost impossible without removal (no fishing in after).VD comes into play if loading circuits at more than 12 amps. Can't seem to bring myself to pull all in #10awg. Am being told that the current scenario for the shop at the old house is just plugging into "standard 110" and never having a problem. Thoughts appreciated.
