When looking at a feeder, that needs derated for 4 CCC and then checked for voltage drop, what is the procedure; which gets done first? I would think they are independent with the VD calc being based on the 3CCC non-derated wire size. Compare that to the derated wire size for 4CCC and select the larger. Assuming they both calc to the same wire size, the difference would be the ground as derating does not change ground size but the VD calc will. I have done a search on this with no solid luck.
