al borlan
- Newport, Mi.
Can I extend conductors and use the 10 foot tape Rule?
I replaced a 150 amp water heater with a smaller 43 amp tank. The circuit that fed the old htr is a dedicated 150 amp breaker in an old motor control center with 1/0 conductors that are now too short. Can I extend/Tap the circuit with a 3 foot length of #6 conductors terminating into a 60 amp fused disconnect and then continue into the tanks fuse block enclosure. MCC does not have any spare buckets that I can use.
It is not a big deal (Just money) to extend the 1/0 conductors and install a 200a disconnect with fuse reducers, Just want to know if that is a legitamate use of the ten foot tap rule.
Al
Al
