rojay
- Chicago,IL USA
I apologize for the length of this post first of all. I have to preface my question by saying I do not have much experience dealing with corner grounded delta systems. Recently, I was asked to inspect some work that was done by another contractor and came across multiple issues that appear to my eyes to be code violations. On the rooftop of a 10 story building is a 200 amp 120/240 volt single phase panel fed from the secondary side of a single phase 37.5 kva transformer. Transformer has single phase 480 coming to the primary side. Inside the transformer disconnect switch (unfused 100 amp) are A and C phases with a green equipment ground that is landed to a ground lug inside the disconnect that ties the equipment ground from the line side supply to the load side feeding the transformer primary. So far, so good in my eyes. Where I ran into issues was the basement where the feeder originates. The feeder came from the service switchgear into a junction box where it ties into an Emon sub meter. All three phases were brought to the meter with an equipment ground. First I don't understand why all three phases were needed for a single phase application. B-phase was orange which I believe needs to be white or gray? The equipment ground was landed to a ground lug inside the splice box and a ground was provided for the Emon case. That's where the EG ended. The #2 green that I assumed was a EGC on the roof was spliced to the orange B phase wire inside the splice box. My thoughts on correcting this installation would be first to only bring phases A and C to the Emon along with an EGC. Emon would be wired only using 2 current sensors and the remaining pair of contacts inside would need to be jumped out. I don't have enough experience with corner grounded deltas or Emon meters to know if I'm on the right track here. Does anyone have any thoughts?
