Loaded with splices:lol:Maybe that is why the cover was left on. :lol:
I can appreciate that kind of work. No wires wrapping around or crossing over another, takes a special ingredient in a person's psyche to do that.
I wouldn't demote him to that.The guy missed his calling as an artist
Probably don't want to see what it does above the ceiling![]()
I thought the same thing - rat nest.
That is awesome!!!:thumbsup:A picture I just ran into on the internet.
Idle hands are the devil's workshop.
They certainly used a lot of wall space that could be used for other equipment - there is space for another panel to the right but there are all those cables in the way.I think the install would look cleaner having branch circuits entering trough and then nippiling
into panel with conduits
I doubt it. Someone who does this kind of work has serious OCD. Not saying that it's per se a bad thing, but making a rat's nest in the ceiling would probably maker his/her head explode.
Southwire?s Romex? SIMpull ? Type NMD90 cables are available as two- or three-conductor
cables, with bare grounding conductor
? The construction is manufactured using annealed (soft) copper conductors?compressed
stranding for the stranded conductors; a 90?C rated thermoplastic polyvinyl chloride (PVC)
insulation and a nylon jacket for the individual conductors; and a PVC jacket surrounding
the overall construction
? The cable jacket is color coded for quick size identification; White - 14 AWG, Yellow -
12 AWG, Orange - 10 AWG, and White - 8 AWG and 6 AWG
? For two-conductor cable, one conductor has white insulation and the second conductor
has black insulation
? For the three-conductor cable, one conductor has white insulation, one conductor has
black insulation, and the third conductor has red insulation
? A blue overall jacket is available with two-conductor cable size 14 AWG
? A red overall jacket is available with two-conductor cables?sizes 14 AWG, 12 AWG,
10 AWG, and 8 AWG: phase conductors will be red and black
? Unique SIM (SlikQuik? Infused Membrane) Jacket? construction allows for 50%
reduction in pulling force resulting in easier installation, easier stripping, reduced
burn-thru, and tear resistance
Possible that Canada code doesn't allow reidentification of white (or whatever color is the grounded conductor there) so you must use this cable for circuits not using a grounded conductor?This is from Southwire for Canadian NM cable. Looks like the red jacket is for DP situations. Black and red wire along with a ground
If it is Canada, they never had the 42 circuit limit that the NEC had.Looks like there are 49 cables going in that panel, I wonder how many twin breakers are in there.
Did this come from a Russian (I think) website.. That was were I found it using search by image thru google
Crazy depends on what you are used to, they could look at what we run and call us crazy.It could have come from a Russian site, but the equipment positively looks North American (Canadian perhaps?)
This is what the loadcenters look like in Russia and most of Europe:
That part of the world is a free-for-all when it comes to our trade..
No codes being followed, and any trade standards used are guidelines at best.
With their residential supply being single-phase 230 volts hot leg to grounded neutral, as a standard, they OCP 1.5 mm2 conductors (roughly an equivalent of 16 awg) at 10A, and 2.5 mm2 conductors (12 AWG) at 16A, allowing to them to carry 2,300 watts on 14AWG and 3680 watts on 12 AWG conductors..
Crazy!
I personally feel that 230 volts single phase like they use is possibly a better deal then 120/240 for most things.
