This was a long time ago so things might have changed, but I helped on a study done by Costco on their POS system failures. They had a big problem because they insisted on buying used machines, so they were already compromised. They had a facility outside of Seattle that was essentially a bone yard where a crew of techs stripped good parts out of failed registers to make other ones work. It was amazing how much time and effort they spent trying to get away with used stuff, yet the data from their POS system was incredibly critical to their operation. They bought ferroresonant power conditioners for all of their register stands and cut the failure rate in half.
We later did a time and motion study on one of their average stores for the purpose of determining if it was worth it to upgrade to UPS systems so that if the power failed, they could at least finish the transactions in process and maybe a few more with 10 minutes of backup power. With 36 registers running they were moving almost 200 transactions per hour through there, each one an average of $130 (this was in 2001 I think). So every time power went out, they were losing $5400 in immediate transactions, upward of $20K if they could finish more. Turned out they were too cheap to install backup generators too, plus they used the cheapest minimum emergency exit lights, so if power went out they had to clear the store in 10 minutes anyway and the $5400 recovery was irrelevant to them.
