-MIKE-
 - Franklin, TN, USA
Water wicks into the cable from an exposed end in or subject to a deluge of water.... The paper insulation around the bare ground wire is soaking wet. How the heck can this happen? Do I have to pull it all and rewire?
4.6 Wire, Cable and Flexible Cords
When any wire or cable product is exposed to water, any metallic component (such as the conductor, metallic shield, or armor) is subject to corrosion that can damage the component itself and/or cause termination failures. If water remains in medium voltage cable, it could accelerate insulation deterioration, causing premature failure. Wire and cable listed for only dry locations may become a shock hazard when energized after being exposed to water.
Any recommendations for reconditioning wire and cable in Section 1.0 are based on the assumption that the water contains no high concentrations of chemicals, oils, etc. If it is suspected that the water has unusual contaminants, such as may be found in some floodwater, the manufacturer should be consulted before any decision is made to continue using any wire or cable products.
Maybe they had it stored in their outside warehouse at some point. A little rain probably doesn't hurt too much, but maybe you got the reel from the bottom of the stack and it was submerged at some point. I'd demand a replacement myself, if you already have the entire thing installed... don't know what they will say, but you can always tell them you will get a replacement at HD and maybe they will at least compromise - you should have maybe caught it sooner.This is straight from the shelves at Lowes.
I only discovered it AFTER wiring a wall and now I am PISSED! :rant:
I've never run across this before. Can anyone tell me if it's normal or at least if it's something to be concerned with?
The inside of this Romex wire is wet. The paper insulation around the bare ground wire is soaking wet. How the heck can this happen? Do I have to pull it all and rewire?
Do you put some kind of tattle tale inside the wrapper, otherwise how would you even know a week after the install?As a manufacturer of such wire and cable (actually Nonmetallic-Sheathed Cable) I would not warranty it....
Good point, If installing a short length and connecting it right away you probably catch it before the entire reel is pulled in, which was maybe what was on my mind to some extent, but rough in of a new building or significant addition and you are more likely run the whole reel without ever stipping off any sheath.How many times have you stripped the insulation off romex before pulling it through walls?![]()
It's just a general statement...lol....It's from my days at NEMA...lolDo you put some kind of tattle tale inside the wrapper, otherwise how would you even know a week after the install?
