keithcsz
- Cincinnati, OH, USA
I am working on an application where we typically wire a diode directly to a window heater. However, due to circumstance, this time we will need to have a diode at the subpanel and run a wire (a couple feet) to the window heater.
My thought process was to have a terminal block (called 17) with our 110VAC, and then have a terminal block below (17A) it that is jumpered to terminal block 17 by the diode. We would then wire the window heater to 17A.
As far as using the diode at the terminal block in this manner.. does anyone see any potential concerns? Would it be better to simply cut the leads as short as we can for the diode, or would shrink tubing, etc be a better option?
Thanks so much for the help!
