svenoaks
- Deerfield Beach, FL, USA
With emergency lighting designed to transfer to an emergency source such as a generator upon failure of the normal circuit, with a device such as the Bodine emergency lighting control relay GTD20A (see attached pdf), can the switch (be it a regular wall switch, occupancy, or lighting control panel relay) be located on the load side of the Bodine relay? In this case the lighting will not come on when normal power fails and the switch has the lighting turned off.
What would be the code section from NEC, NFPA 101 or other that prohibits such an installation? I can't seem to find anything.
