Ranch meter panel & load center bonding
garrcass
Should a load center connected to a ranch panel with triplex be bonded?
The load center is the branch circuit distribution source for the house it's in the garage.
Its effectively a sub panel therefore i say it shouldn't be bonded my employer says otherwise.
It's a outdoor pole mounted meter main with a small amount of distribution and 200 amp feed through bussing.. yes garage and house are one building and This is a new residents
We are under 08 pretty sure our jurisdiction is only 4 years behind on the applicable code book. It was a real abortion I wanted to flip the guts and 're land the feeds I was told the panel was fine. They blocked the ground and neutral bars pretty good.uploadfromtaptalk1427938056568.jpg
