Gary Alzaga
- montebello, Ca
Hi everyone,
Basic question here. Residential pole mounted transformers and many other transformers that produce a neutral have that neutral "center taped" from a current carrying coil in the transformer and bonded to ground. My question is why doesn't the current in the coil short threw that neutral to ground?
I understand a neutral in a transformer before bonded to ground has equal potential with reference to the ungrounded/hot conductors and once it is bonded to ground it creates a conductor that has zero potential to its surrounding environment. This is all done in the name of safety in case an ungrounded/hot conductor comes in contact with ground or anything grounded it will trip an over-currnet protection device.
Now Ive read if just one current carrying conductor is connected to ground their is originally no potential difference so nothing happens. That makes sense but theoretically their is not just one conductor connected to ground. At every transformer there is a neutral connected to ground. Is their too much resistance between the different neutrals to constitute a short or is it cause all the neutrals are in phase? Or am I totally off? Thanks in advance for the help. It is much appreciated.
Gary
Gary
