mkgrady
- Massachusetts
I'm wiring a complete home renovation. Part of the renovation includes a swimming pool. I need to run a feed from the main panel to a pool subpanel that will be mounted outside on an outside wall of the home. The pool electrician will provide and install the pool subpanel and all the circuits needed for the pool. The pool electrician said the feeder MUST be in conduit (I want to use Romex) I don't see that anywhere in the NEC. Is he right, and if so, where can I find that requirement in 680? I don't know if it matters but there is a meter/main feeding what i am calling the main panel, so technically the pool is being fed from a subpanel.
I would just give the guy the circuit in conduit as the work is T&M but the route is already jam packed with an amazing amount of wires and radiant heat pipes. There just isn't any cost effective way to put this run in conduit and I don't want to waste the customers money if not needed.
