Q1: If you have a multifamily dwelling with separate service disconnecting means for each, does 230.79(C) apply to those disconnects?a "service feeder" would be kin to a "bear elephant" or "kangaroo turtle"..
can't be both.
Therein lies the problem. If its a service Art 230 has a minimum size of 100 amp for a SF dwelling. If it's an outside Art 225 has a minimum in 225.39.
If it's an inside feeder, I see no minimum other than as required by Art 220,
Q2: If you have a multifamily dwelling with single service disconnecting means, then supply meters and outside disconnects for each unit, does 225.39(C) apply to those disconnects?
