ok so here was my findings its a combination of things that is not quite over yet
the lights are actually 2.5 yrs old (time apparently really flies for me) the original bulbs by two years over half were burnt out so THEY replaced them with what the little sticker inside the housing said to replace with. with in four months they have all burnt out. so when I got there today I tested voltage drop and amperage, everything was good started checking the bulbs the original bulbs did not match the sticker in housing, so I took the light apart and the original bulbs match the ballast but the sticker in the housing recommends the wrong bulb for the light. we are now in emails with manufacturer to find out how we are gonna handle all this.
I sort of want to see this one get tried out in place of MH so I can know how it went and just show 'em to those lame LEDs
It's a 330W CMH with 90 CRI that matches 400W MH and make those LEDs gasp.
It costs like $60/lamp, so I used $50/lamp over normal HID since you can get ghetto 400W MH for like $10.
Labor is $0 since the issue needs to get addressed anyways.
It just screws in place of 400W of all kinds and supposed to save you 60-70W/lamp. In 18 fixtures, you shave off about 1.2kW in demand so if the building peaks at 4-6PM time frame in the winter, it could cut a little bit on demand charge.
Ignoring that, they should cut 391kWh/month using 65W per lamp x 11 hr/day x 18 lamps and at 10c/kWh and 3% IR, the $50/lamp added cost cancels out at the end just in time for warranty expiration. If they last as long as they should (20-24K hours), they should go another 1.5 to 2 years before needing replacement all at once and actually continue to yield them $39 savings each month. Some utilities have rebates, but I didn't use them in my math. If incentives are available to change out these lamps, then more power to them.
They say these work with M59 and M165 probe start ballast and C185, M128, M135, M155 and M172 pulse start ballast.
You just got to know if the fixture needs the 9 incher or 12 incher bulb.
http://www.usa.lighting.philips.com/pwc_li/us_en/connect/tools_literature/downloads/p-6051.pdf
http://www.usa.lighting.philips.com/connect/tools_literature/downloads/p-6000.pdf
