Ravenvalor
- Triad region of NC
- Electrician
Anyone ever troubleshoot an electrical system in a home or commercial building with an electric fence energizer?
Are you talking about using the charger as a tool?
My boss hooks up a wire to his trucks ignition coil and clips the other end to a lead in old electric ceiling heat. Walks around with a stethoscope and listens for the tick, tick, tick, before he makes a surgical insision.
I have never done it myself, but I know it works. He pulls a spark plug wire off, jams an adaptor he made in the socket and hooks it up to the conductors feeding the ceiling heat.Yes I was talking about using the charger to find loose connections or maybe shorts.
Can you please elaborate on the ignition method?
It is and he is. He's done a lot of other cool stuff.....made his own ceiling fan boxes before they were required because he had a ceiling fan crash down.....made his own PVC expansion joints when they became code required but none of the local supply houses were stocking them yet....made his own ground rod driver attachment for a Hilti.......underground boring tools, hot box for PVC bending, extra long hole saws,....there is more that I can't think of right now.That is ingenious!
What exactly did he hook this testing device up to?
