I'm doing a house Reno where they installed icineen (sp?) insulation. It is closed cell so it is pretty dense. Some of my boxes are filled with the crap. Anybody have any ideas on an easy way to prevent this or if it could cause any future issues. One guy told me the stuff is flammable but I suppose the blue boxes are too. I plan do dig and scrape the stuff out and off the wires.
that is NOT gonna be any fun. what i do on commercial work, where i use steel boxes, is i make up the
boxes before i put on the rings, and put three 3 1/2" bar coasters in each box, then put the ring on.
the wire stays behind the coasters, the roto zip pushes back the coasters, and doesn't cut thru, the mud
builds up on the coaster instead of filling the box, and you rip them out with needle nose, and trim.
i did cat 6 jacks, made them up, and put them behind the bar coasters. 250 of them. pulled them out,
snapped them into trim plates, and screwed them down.... zero failures at gigabit eithernet speed.
had three data lines per box.
