sign ballast
enireh
Canyon Lake,TX
I installed two 120 volt ho 4 ft. 4 lamp ballast in a sign. On one of them two lamps refuse to burn. I changed the sockets, wired them from working lamps still nothing. Could this be the new sockets are not bonded well to the sign? I changed them out because of rust.
Bad Ballast? Bad lamps?
The sockets are not bonded to the sign (or shouldn't be if they are now).
I lean towards bad ballast, maybe swap the wiring from the known good ballast to the lamp and socket combination you are having a problem with.
sign ballast
I did all these things
"Grounding ballasts and luminaires is also important to ensure the proper starting of the fluorescent lamp, especially when working with magnetic ballasts. A metal reflector creates a capacitive path to ground through the wall of the fluorescent tube, which aids in ionizing the tube?s gases and triggers conduction. Once the tube has started, the supplementary capacitance becomes obsolete because the impedance in the ballast circuit is actually lower than this capacitive path."
On horseshoe fluroescents they often run a foil strip along the tube for grounding purposes. I could see an issue with signage where there's no nearby ground plane since the tubes often span open air.
My first thought is along the line with Rick's post. Do you have all the metal covers, etc. in place ?
