xguard
- Baton Rouge, LA
We have an aerial feeder from one building supplying another. The supply side (load side of the feeder ocpd) of the feeder uses a bare neutral messenger that is directly electrically connected to the metal building where it exits, ie the clamp supporting the messenger is bolted to the building, no insulator. The bare neutral messenger is also routed through a metal conduit prior to exiting the building. Any thoughts on either of these? Thanks.
