Kurta
- Fernandina Beach USA
I have an application feeding 12Vdc from above the ceiling. Power supply is mounted in a 4 sq. box in the ceiling. Feeding the 12Vdc from the power supply inside a sheet rock wall approximately 6 feet to a ribbon (tape light) surface mounted on the sheet rock. The building is an assisted living facility. (Commercial / healthcare).
Does the 12Vdc conductor need to be inside a wireway /conduit /flex? Or is a PVC jacketed
two conductor cable sufficient?
