The start contactor is failing mechanically, meaning jammed closed, no voltage across coil. If your familiar with these, both the run bank and the start bank come with an extra cap not in the circuit. After I lost the first contactor and caps, when I fired the thing back up the start contactor would close, open, close and open again in about 2 seconds. I put the other start cap in the circuit and all was well for about 8 months.
Important to note here that Ronk has outstanding tech support and after the first cap/contactor failure, a lengthy call between them and myself it was determined the unit was functioning properly.
I have installed 4 or 5 of these things and never had a call back on the others.
