Hi,
Have a friend that just had a panel upgrade done at his home in LA.
The electrician who did the job did not run any EGC's to any of the
receptacles or anywhere else.Also, The house is very old and has all
rigid & flex. Will this pass inspection?
The panel upgrade has nothing to do with the grounding of the receptacles unless it is a code of the city.
Even though the panel is upgraded the rest of the house does not need to be updated.
Cities in CA can no longer make codes up and enforce them unless there are one of the three express findings. Then they must be passed by ordinance and filed for approval by the State BSC. How well a city AHJ enforces what is already on the books is another thing.
Thanks. :thumbsup::thumbsup:
Good to know. I did not know that.
It has been that way for as long as I can remember but never challenged by contractors or enforced by the state. There are may BS local codes around that do not meet any of the requirements to be necessary. Even if the amendments do get submitted to the state they are just dumped into a file and never reviewed.
But, he ran new conductors into the house, which makes it new work no?
So he rewired the entire house using existing metallic conduits? Or just upgraded the main service panel?
yes.
Steel flex if pulled new will generally need a EGC.
Aluminum flex may not.
However unless it has changed , Alflex certain type is approved in certain conditions up to 20 amps. , In the past I have only seen the tag on Alflex products stating it is listed for such.
Oh and CA is on the 2013 California Electrical code. there are differences.
