I installed a Generac 200A ATS with a main Cir Brk adjacent to a existing Main 200A panel with a 2" rigid close nipple. The main bonding jumper is attached to the metal ATS enclosure. Why is it that the EGC bond wires have to be separated from the neutral bar when both of these metal enclosures are joined together by the rigid nipple and the neutral connections are one in the same? I can understand if I used PVC or SER between the two.What's the electrical hazard? I know the existing MDP is now called a sub panel but whats the difference if this ATS had circuit bro built in?
