NickL
New member
- New Jersey
Hey, spoke with many in the field and get many different views in regard to 0-10 Volt Dimmer wiring. As an"old school" (licensed in 1986) electrician the code requirement was to always keep Low Voltage Wiring out of Line Voltage Use Raceways. So, along comes 0-10V Dimming. As I read it in the code, you can now mix the Low Voltage 0-10 V. wiring within the Line Voltage Raceway as long as the Insulation Properties of the Conductors are the same. If that's the requirement, why do I keep finding guys who throw everything in one raceway without regard to the insulation type, I've even seen Cat5 co-mingled in Line Voltage Raceways for 0-10 signalling. That just can't be right!
Let me hear your thoughts, opinions, your installations and some crazy installations you found regarding 0-10 Volt Dimming Wiring.
