Jameshucks
New member
- Horry county
will code allow me to use thin line breakers if so is it a good ting to do?:?
Welcome :thumbsup:will code allow me to use thin line breakers if so is it a good ting to do?:?
Welcome :thumbsup:
I think the non-slang term is tandem breakers.
I have heard them called tandem, Piggy back (Sq. D), & twins.
Ever since the development of class CTL breakers 30 to 40 years ago you can not plug a class CTL breaker in a slot not designed to accept it - without modifying the breaker to defeat the rejection feature built into it. There are however still non-CTL breakers out there that will plug into any slot in the panel - but at very least by doing so you are violating listing instructions unless you are using it as a replacement for a previously allowed non CTL assembly.will code allow me to use thin line breakers if so is it a good ting to do?:?
Tandem breakers can be a life saver when you have a already full panel. GE & SQ D both utilize features on their breakers that limit where in the panel you can install them. SQ D also has a selection of tandem breakers without the "hook".
To me the first two images are twin breakers, the third shows a tandem breaker.
The first and last images are both QO series, but the last image is an older version. Square D has named both of them "tandem" type breakers in catalogs and application data on panel labels as well.
I don't know off hand what Eaton/Cutler Hammer addresses their version as.
Eaton C/H designates them as twins. I've noticed that counter guys at supply houses that distribute Square D tend to give me blank stares when I ask for a twin breaker. I guess that's the effect of trainingI think Siemens also uses "twin" but I'm not sure about the GE type that have that form factor but can actually hook onto both legs and be used as a 240V breaker in certain panels.
I seem to recall GE addressing them as 1/2 inch and 1 inch wide breakers and not so much as twins or tandems.
I think you're right and I was confused. I don't see many GE panels, but now I remember that they make 1" two-pole breakers for that series. That series always throws me off because you can use 1/2" single poles, 1" single poles, 1" double poles and 2" double poles. Goofy.
I call all of them "space savers"........because they are.
