I have a LFNC metal fitting that is UL listed and marked LNMC-B for Liquid Tight Flexible Nonmetallic Conduit. The question is if it can be used on an installation connecting to a nonmetallic box, cover, etc. and not need to be bonded? I checked the UL whitebook Category DWFV Conduit and Fittings and specifically looked under the LTNC fittings and it didn't state any limitations to it being needed to be bonded if used in a connection to nonmetallic equipment. I also read 250.96A and it states " Metal raceways, cable armor, cable sheath, enclosures, frames, fittings,and other non current carrying parts that are to serve as equipment grounding conductors, with or without the use of supplementary equipment grounding conductors, shall be bonded where necessary to ensure electrical continuity and the capacity to conduct safely any fault current likely to be imposed on them." Am I right on this?
