joshtrevino
- Beaumont, TX
I am doing a coordination study for an existing switch gear that formerly operated at 2300V, but will now be operating at 4160V. The one motor that remains on the switchgear will be rewound to operate at 4160V.
The motor is 300hp, 2-pole (3550rpm). My issue is that my ETAP library does not have 2-pole motor curves built into it, only 4-pole motor curves. ETAP technical support does not appear to have a library to download with 2-pole motor starting and damage curves. I have contacted Siemens, but I am unsure how much it will help as this is an existing motor that will be rewound.
Question - Does motor rpm / number of poles significantly change the starting and damage curves of a motor? Could I conservatively use the 300hp 4-pole curves built into the ETAP library to substitute for the 2-pole motor?
Please excuse me if this is an ignorant question as I am new to software coordination studies.
