danno1202
- Mounds View, Minnesota
I am currently planning the installation of a residential service on a rural home. This will be a service that has two direct meters, one for the off peak power and one for the normal power. My power company requires that the meter pedestal be located at least 50' from the house. The off peak load will be an electrical thermal storage furnace and a 100 gallon water heater.
I will need to run a 200 amp service lateral for the off peak, and a 100 amp lateral for the normal power. Both laterals will be run out to the meter pedestal.
How do I determine the service wire sizes? I know this sounds like a dumb question, but am I allowed to use the reduced sizes for residential service wires in the code? It says something about serving the "entire load", so I'm thinking not. Or do I just go with 100 and 200 amp rated wires and that's it?
Thanks much.
Thanks much.
