natepifer
- lancaster pa
I read the Rec. outlet being anything from a single rec all the way to a 3 gang box with 3 duplexs.
When the code says you need one Rec outlet per space i see that as 1 outlet box no matter the size of that box and amount of recs it contains.
in my opinion a 3 car garage would need 3 totally separate Rec outlets or 3 totally separate outlet boxes be it single gang 2 gang 3 gang and so forth. Locations should be in reference to each space be it centered or to the left or right of the space.
