jaylectricity
- Massachusetts
- licensed journeyman electrician
Testing a receptacle I found 122V hot to neutral and hot to ground. The weird thing is when I had one lead on the hot and the other in the air not touching anything conductive the meter was reading about 30V. It fluctuated between 28-35 while I held it there.
Is there any chance that the air was dry or wet enough to read voltage through the air? This room is at grade level with tile floor.
