That breaker is discontinue, this breaker is for an electric furnace in a mobile home. We purchased a double pole 60 amps breaker and 2 single 40 amps breakers to assemble and use it, we need to remove the tie on the 60 and drill through the handles of the four breakers to install the tie with the steel rod, so that "it can be a 4 poles breaker"
I have some doubt about this, as this is a field modification and wonder if, is there any short the whole breaker will trip.
I appreciate your input - Thank
