TrickleCharge
- CA
Good morning.....I have a 600A service that was installed and not per the original design according to the plans. There are 7 meters, (6) 100A and (1) 400 A. The service is only using 4 total and they said they will have the utility company block out the other ones not in use. This is for a small retail strip that probably would not have the need for more than the 4 meters. I guess they could later on use the other 3 if they divided it up, but would it be acceptable to have the remaining 3 blocked off with just the clear plastic cover? Or does this violate the 6 disconnect rule?
