rknelectric
- United States
Researchers wanted to test their new LED lighting system in the existing conference room. The room lights are fluorescent T8, 120 VAC. New LED strips will be installed inside existing luminaries and fed from the power conversion box 325 VDC via existing wires (no neutral - one wire is +162.5V, another -162.5V). Existing wires will be disconnected from the panel and connected to the power box via pull box and protected with fuses. The power conversion box will be fed from the same 15A CB in the panel. Is there any danger/safety issues with this installation? Thank you in advance.
