I am in the process of verifying a load calculation for a 480V substation in an industrial facility and was having trouble estimating the existing loading on several 480V and 120/208V panelboards that are located in the facility. The substation feeds several downstream MCC's which are easy to calculate the load on since the motor loads on the MCC's are identified and I can use NEC 430.24 to calculate the load on each MCC.
Several of these MCC's feed 480V panelbaords and 120/208V panelbaords (via transformers) that do not have really good documentation on what the existing loading on the panelbaords are. Obviously with several branch circuits on each of these panelbaords it would take a long time to trace out each circuit and identify the connected load kVA rating (Unlike MCC's where you can easily identify motor loads). We could obviously meter the load on each of these panels but that would also take some time.
Is there a reasonable assumption that others have used in the past for loading on existing panelbaords when branch circuit loads are not known? Can you use a certain percentage of the panel or transformer rating? Any suggestions would be appreciated.
