KnobnTube
I was reading the thread below:
http://forums.mikeholt.com/showthread.php?t=167941&highlight=single+phase+208Y+panel
What panel does one use for the application on the single phase 208?
Looking at manufacturers, they have their ratings very explicit on panelboards.
Example:
3 phase panels specifiy they can be used for either of the 208 or 240 application.
Schneider Electric Load Center, 125 A - Panel Boards - QO312L125G
Voltage Rating 208Y/120 Vac - 240/120 Vac Delta - 240 Vac Delta
Single phase, however is explicit for only 240 volt.
SCHNEIDER ELECTRIC QO120M100
Voltage Rating 120/240 Vac
So, how does one use the standard 120/240 for a single phase 208 application when the manufacturer does not provide the rating in the instructions/specifications?
Just curious here, I understand 240 volt rated is higher than 208, but then why do they specify the 2 with 3 phases, it would have no meaning.
So there has to be a reason for the single phase panels not to be dual rated?
Thanks
Example:
Thanks
