Hello. I've wired maybe a half dozen pools. Those pools had several things going on do I would install an exterior panel and feed whatever was needed from it.
For a single motor for an above ground pool. There will be the circuit breaker for the branch circuit and the receptacle and plug at the motor for service disconnect.
The controller or time clock. Does it have to be within sight of anything.
Does the motor disconnect also have to disconnect the controller.
I'm not sure what this job that I'm going to look at is about but hypothetically. Can the circuit go to a garage or under a deck or someplace remote from a motor mount the time clock then the power from there out to the motor receptacle ?
Thank you
Thank you
