Stray Voltage Monitor
newt
I'm in the market for a stray voltage monitor for dairy farms the only one I found was an eagle sr4 for 7000 dollars does anyone know of any other make of monitors
simplest ones I have seen is when the cows don't want to go near something - there is trouble there:happyyes:
How many monitors are you going to need to ensure you have all possible problem areas monitored? I don't see how one monitor is going to cover the entire facility.
you can have four inputs on one stray voltage meter 3 cow contact points and one neutral to ground voltage
