Sierrasparky
- USA
- Electrician ,contractor
Why would a Gas range require a dedicated max 15 amp circuit. That is what the instructions say.
Three speculations:Why would a Gas range require a dedicated max 15 amp circuit. That is what the instructions say.
Three speculations:
1. The glow bar igniters take a lot of power.
2. The spark igniters might cause interference to other equipment.
3. The manufacturer just wants a dedicated circuit as CYA.
Kitchens were added to AFCI requirements in the 2014 NEC so, it looks like that will have to be. However, I would suspect that the spark ignition on the burners may pose a problem. BTW, I vote with Little Bill on this. # 3 is a CYA type thing.would the 2014 NEC require this to be either GFCI or AFCI?
I installed a circuit for a wine cooler. Very small unit that fit under the kitchen counter. The draw was something like 1 amp or less and it called for an individual circuit-- they are nuts. Manufacturer is just trying to make sure nothing else causes havoc on their digital stuff-- that's my opinion anyway.
Three speculations:
I'm guessing they think it is possible to have some interference from other electronic. IDKWhat will cause havoc with the electronics if there were other items on that circuits?
