Does the NEC address the maximum number turns in a conduit run.  I seem to remember if a conduit run had more than 360 degrees of turns, a pull box or pulling C, LB, etc had to be installed.
Is there a code restriction, that you cannot continuously pull through more than 360 degrees? If I have a conduit run with (5) 90s can I pull straight through? I would have C throughout the run to help with inserting the pulling string and apply pulling lubricant.
