Still having a hard time getting this in my thick skull.
There is an ac unit.
It requires 24 amps and an hvac breaker @ 40 amps.
The wire will be #10 on a 40 amp brk and the disconnect at the unit would have to be rated for the 40 amps (60 amp non fused) correct?
It requires 24 amps and a fused ocp at 40 amps.
The wire will be #10 on a 40,50,100 amp breaker?? Feeding a 60 amp disc fused at 40 amps.
What would be the limit or max ocp of the breaker have to be supplying the circuit?
thank you
thank you
