Well, today I am a pest. Are you familiar with this type of feeder? Less expensive than conventional wiring in conduit? Familiar with prices?
Underground Service Entrance Cable. 600 Volt. AlumaFlex ? Aluminum Alloy (AA-8176) Conductors.
Cross-linked Polyethylene (XLP) Insulation. Sunlight Resistant.
Cable shall be UL-listed Type RHH or RHW-2 or USE-2, suitable for direct burial and operation at 600 volts. Conductors shall be AlumaFlex TM aluminum alloy as manufactured by Southwire Company or approved equal. The cable shall contain a triple extruded white striped neutral conductor and a solid green grounding conductor to eliminate the need for field marking per the National Electrical Code.
RECOMMENDED SAMPLE SPECIFICATIONS:
